Supercharger for '87 GTA (LB9)
Old Feb 28, 2001 | 04:05 AM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
Im looking into throwing a supercharger onto a remaufactured 305 im going to be getting. I have the choice between purchasing one with Flat Tappet cams or Hydraulic Rollers. I was wondering which would be best. Also, to purchase the right supercharger for my car what would i need to know about the motor.
Old Feb 28, 2001 | 12:49 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
go with the roller cam, it's correct for 1987 cars.
As for the engine, you'll need to determine what pulleys are gonna be on it. If you have a v-belt setup (85-87 factory setup), there's only one supercharger kit available for tpi. That's the paxton sn9X kit. If you go with serpentine belts (88-92 factory), there's a world more options open to you.
Another thing you'll want to know about the engine is what compression it has, and what rings, pistons, and rods are in it. A high compression motor is not a good mix with a supercharger. Also, with weaker pistons, rods, and rings, there will be a definite limit to what kind of boost you can run.
Old Feb 28, 2001 | 11:12 PM
87POSGTA's Avatar
Car: 1989 Firebird
I wanna Use serpentine belts but will the set-up for the 88-up work with what i got?
Old Mar 1, 2001 | 12:51 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
It will work. Here is a thread about it. Be sure to read the replies on it from willie & guido.
https://www.thirdgen.org/messgboard/...ML/000266.html
Also about the roller cam, not only is it correct for the car as stated above ('87 & newer had rollers), you will get better gas milage, more power potential, & better oil life from it.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
[This message has been edited by IROCKZ4me (edited February 28, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
bigjay89gta
Oct 15, 2015 08:04 AM
2012sergen11
Oct 13, 2015 07:38 PM
Dragonsys
Sep 25, 2015 03:51 PM
