do i need to and a fuel pump for 100-150 shot?
Old Mar 6, 2001 | 09:10 PM
bad camaro RS's Avatar
i have a ac delco stock replacement pump that a tr old will it be ok for 100-150 shot of n.o.s? i have the kit thats made for my car by compucar thanks
Old Mar 6, 2001 | 11:42 PM
The ODB's Avatar
A 100 shot (about a #47 jet) will be no problem at all.
If you want more then I would run another pump.
Old Mar 8, 2001 | 01:08 PM
theformula's Avatar
Just watch your fuel pressure gauge under boost. If the pressure decreases you need a new pump, if it rises , your fine.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (4700rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
