How bad is nitrous for your car?
Old Mar 12, 2001 | 09:06 AM
AcSeb's Avatar
I was considering getting nitrous for my car but if it's just going to tear the **** out of the engine I won't get it. Anybody know exactly what it does and how it works or how you could safeguard yourself from blowing your motor up?
Old Mar 12, 2001 | 12:10 PM
SpRaYd91Z28's Avatar
I would look in the tech articles...But to make sure your motor does not explode, or kill it...Make sure you upgrade your fuel system. I went with a 255ltr/hr fuel pump, and a new fuel filter...make sure to replace ur fuel filter often....IMHO I think it is worth the investment. Took off over a second on my E.T. with 100shot.
Zach
Old Mar 12, 2001 | 05:49 PM
precision350's Avatar
No matter what you do, if you want to go faster, bolt on stuff is going to put more stress on a motor. As for nitrous, the way it works is it basically adds more burnable oxygen. Therfore you need to compensate it with more fuel. Too much fuel=ok!! Not enough fuel=bye-bye motor. Just be smart and follow what the manufacturer says, and you shouldn't have a problem.
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
255 lph Holley fuel pump
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time before any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison, Colorado Bandimere Speedway
Old Mar 14, 2001 | 06:18 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The above posts are pretty much right.
Any time you add power to an engine you increase stresses.
Properly used, nitrous won't stress your engine much more than any other modification(s) making the same power.
The main concern with nitrous (or any other mod) is that the engine doesn't detonate (knock) under load.
Too much timing and/or not enough fuel will cause that.
Nitrous oxide is an oxidizer, and a nitrous kit adds fuel and nitrous to make more power.
The best way to safe guard a nitrous inhaling engine is:
  • know what your spark timing is, and have it set correctly. If the stock PROM (chip) Is still being used you will be ok with stock timing while using a nitrous kit up to around 150 HP. If you have an after market PROM you will need to reduce timing advance a few (2°-4° or so) degrees.
  • Make sure your fuel system is up to the task. The stock pump should be good up to a 125-150 HP (or so) kit. Beyond that a better pump is a good idea. A new fuel filter should be installed at the same time as the nitrous kit and it should be well maintained. Using a fuel pressure safety switch (available as an "add on") with the kit will prevent the nitrous from operating if fuel pressure isn't high enough.
  • Buy lots of replacement rear tires.
    Strangely enough the tread seems to disapear until nothing is left but onion skins. LOL.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
[This message has been edited by IROCKZ4me (edited March 14, 2001).]
Old Mar 17, 2001 | 10:51 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
how strange, you have that problem too? i was begining to think my neighbors cat had suddenly developed a taste for rubber...
Old Mar 19, 2001 | 01:06 AM
Z28Maniac's Avatar
AcSeb, you're gonna juice up the "Mean Yellow Z"? Cool! Your car is the **** in case you didn't already know!
'68 Camaro - Vortec 350
'91 Camaro RS - 305 TBI
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
B_Dubya
Aug 26, 2015 05:09 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
