Cheapest and lowest hp nitrous system??
Old Mar 22, 2001 | 02:39 PM
chicksL69's Avatar
Hi, I was just wondering what kind of nitrous system I could hook up to my car. My engine and it's stats are on my signature, and I want the CHEAPEST and lowest hp rated nitrous, like a 50 shot, something that will not hurt my engine, but enough for a little boost. thanks you
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
Old Mar 24, 2001 | 06:33 PM
MouseCamaro305's Avatar
I would say look at summit magazine or jegs, although they don't always have every kit for your particular motor, they do have quite a variety, since you have keith black pistons you can run well over 50 HP without taking your motor apart, but if 50 is what you want, then I would suggest looking at NOS (nitrous oxide systems) or NXpress for a kit, most of them are adjustable from 50-150 but they come with 100 and 150 jets, youll have to buy the 50 seprately
Old Mar 30, 2001 | 05:10 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
the smallest, most inexpensive N2O kit ive seen is the "sneaky pete" by NOS. unfortunately i dont know if they are still in production. my local performance shop doesnt carry them anymore. next up is the "sniper" by NOS. its a good bang for your buck. BTW, what compression ratio are you running at? if you are 10:1 or less you can throw 100 h.p. easy into that engine without any worries.
[This message has been edited by bottledpower (edited April 03, 2001).]
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ZZ3Astro
Aug 13, 2019 12:57 AM
anesthes
Sep 18, 2015 12:34 PM
angel2794
Sep 8, 2015 06:22 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
