Nitrous Plate location
Old Mar 31, 2001 | 04:15 PM
Havoc's Avatar
I just purchased the Edelbrock Nitrous system and was curious as where to position the plate.I run a one inch carb spacer so does the plate go on top of or below the spacer?What are the pros and cons of either position.The carb is the edelbrock 1407 750 cfm manual choke as part there total power package including cam,heads,and intake.Running about 11 to 1 compression.Have full MSD ignition with timing retard. Does anyone forsee any other problems.
Old Apr 1, 2001 | 05:58 AM
Havoc's Avatar
Could the moderators forward this to the carb board so that it shows up on both forums.
Old Apr 2, 2001 | 08:24 PM
The ODB's Avatar
the plate goes under any spacers you run.
Old Apr 2, 2001 | 10:16 PM
Havoc's Avatar
Again you come to the rescue, thanks ODB.Us local guys gotta stick together.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
