Supercharged 305 or buy a 350 crate?
Old Apr 1, 2001 | 10:31 PM
Golden80's Avatar
I have a LG4 305 in my Corvette right now and was wondering what you all would suggest. Supercharge the LG4 or spend some big bucks on a new crate engine? The LG4 has 8.5:1 compression, correct? It should respond well to NOS or supercharging with that low of a CR. Just wondering what everyones opinion would be.
Matt
Old Apr 2, 2001 | 08:02 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I've had great success with my supercharged 305. One of the best things I enjoy most about my decision to go this route is being able to say to others at the track, "It's only a 305."
I also recognize that I'm in the minority -- that almost everyone else will go with a 350. It's actually cheaper in the long run. So your decision should be based upon what YOU want.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Paxton (6-psig): 12.57 @ 111 mph.
Paxton (6-psig) & 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (10-psig): ?
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Apr 2, 2001 | 11:06 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
If you're keeping the 305, make a 335 stroker. Not only will that be a torquey street engine, but you can still say it's a 305, plus I've seen balanced stroker kits for like $800 complete. Not much top-end, though. Make sure you dont detonate with cast pistons (or hyperutectics, for that matter). 1 or 2 degrees additional retard is better than a crumbled shortblock. If you get a 350 crate, get the ZZ4...best bang-for-the-buck crate engine. Just pop in your cam choice.
Old Apr 3, 2001 | 10:27 AM
JPrevost's Avatar
Car: 91 Red Sled
TPI then zz4 is best bang for buck. If TBI or carb I have to say vortec 350ho engine is best bang for buck (vortec heads flow better above 3000rpm than the vette heads).
I really wish GM would have come out with a zz4 bottom end (better pistons and roller cam) and vortec heads. That would be a great combo if they had the right pistons for lower compression ratio.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
toronto formula
Nov 10, 2015 06:17 AM
st.evel07
Aug 13, 2015 06:15 PM
