to high compression?
Old Apr 26, 2006 | 06:06 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
I have a 383 stroker motor in my 88 iroc.and its running 9.7 to 1 compression is that to high to run a centrifugal blower? And at what psi should i run it. any help would be appreciated. also whats a good blower kit to run on a 88 iroc with a carb. thanks
Old Apr 27, 2006 | 08:02 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
9.7:1 isn't all that bad depending on what your dynamic compression is. What cam are you running?
As far as blowers, you don't need anything crazy b/c you won't use it w/ 9.7:1 compression, I'd suggest a procharger that comes w/ a 3 core intercooler. Depending on the dynamic compression and the tune, you should be able to run between 7-10psi.
Old Apr 27, 2006 | 09:32 AM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
compression
my cam is 498/ 510 lift. I want to get it into the lower 12 if possible, do you think that is possible with 7-10 psi? Why do you say i wont be using the procharger with 9.67 to 1 compression
Old Apr 27, 2006 | 11:51 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
9.7:1 compression is on the high side for running boost. You might be able to get away with some though. I would stay below 6psi.
Shouldn't a naturally aspirated 383 be able to get in the low 12's?
Old Apr 27, 2006 | 02:44 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
383
Some should some shouldnt, this is a pretty mild motor. i got a 383 in my truck that runs low 12's but its got a bigger cam and higher compression and a little better heads. Just depends on whats in the motor
FormulasOnly
Jul 23, 2018 08:47 AM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
