How important are BOVs????????
Old Apr 15, 2001 | 10:59 PM
theformula's Avatar
I'm running 5lbs of boost at 5000RPMs. I had a BOV on there but decided to plug it because I was afraid there was a leak there.
How important is it to have a BOV when you run only 5psi? What is the proper way for it to operate? Is it only supposed to bleed air between gears? or upon acceleration?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 15, 2001 | 11:13 PM
GMI FAST's Avatar
With 5psi, you do not need a bypass valve. It's main purpose is to eliminate reversion air from travelling back through the compressor. This happens when lifting off the throttle. Reversion air will slow down the compressor wheel and cause an excessive load on the bearing. Bad for the bearing! It's secondary purpose is to increase compressor wheel response between gears when you route the bypass valve discharge into the air inlet entering the compressor. This is not as important on a supercharger which uses a belt to turn the compressor wheel. I wouldn't bother using a bypass valve on a supercharger unless I was making at least 15psi of boost or more.
Old Apr 16, 2001 | 12:44 AM
89ProchargedROC's Avatar
GMI, why then when my bypass valve was stuck closed one day my car ran like crap?
i have 12psi at 5500rpm. just wondering
Old Apr 16, 2001 | 09:40 AM
theformula's Avatar
I might put the BOV back on. Any excessive strain on the bearings that doesnt need to be there is NOT going to be there. We all know about the reliability of these Paxtons
Old Apr 16, 2001 | 06:56 PM
GMI FAST's Avatar
Procharged: Don't know. If you're bypass valve was closed, you should make 12 psi of boost. If it was stuck open, then you would have trouble. Not all the compressed air would be reaching the throttle body. Depending on where you vented the valve, the MAF may have been getting goofy airflow readings also.
Old Apr 17, 2001 | 02:28 AM
i meant stuck closed at idle. probably right....since the bypass is BEFORE the MAF...then it was probably reading high when it was stuck closed.
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
