144 Holley Powercharger...
Old May 18, 2001 | 07:51 PM
cica55's Avatar
at least I think that's what it's called..
simple supercharger, single carb setup , I just need to know how tall the supercharger is , so I can make sure that it will fit under the ASCD ram air hood
Old May 18, 2001 | 09:30 PM
Dan W's Avatar
I think the dimensions are on holleys web page.
Old May 19, 2001 | 01:14 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
9 inches tall from back edge of motor below the distributor mount bracket. Then add height of carb and filter.
I am toying with the idea of a Weiand 142 or 177 for my 383......simple design, no intercooler to hassle with nor extra plumbing nor oil cooler etc etc...... I guess that's why the pros use this design!!
Anyone out there have one on their car? Comments?
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old May 19, 2001 | 01:26 AM
Bobalos's Avatar
A buddy of mine used to run one on his Nova, before he stepped up. he is considering going to TT. here is the link to his site.
http://members.aol.com/fastnuf1/index.html#top
I dont recall if he had to have the scoop on it or not. I also think that there is a guy running around here in San Diego that has one under a small cowel hood in a 2nd gen camaro, but for some reason I think that it fits under the factory hood.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old May 19, 2001 | 03:57 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I had one under my third gen' hood & I had to buy an aftermarket hood. Stock hood will not close!!! I bought the daytona hood & it was still kinda close under there! After everything is dialed in U will love the way the car pulls!!With my 8.5-1compression 400sb , 144 b&m with stock dart 200 heads ,edel exh,373 gears,flowmaster 3in muffler, holley 750vac, 268 comp cam ( I know that its not a blower cam!) I was running 12.60@110mph with a 2.05 60ft & thats from real life experience son!
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old May 21, 2001 | 05:19 PM
ANTHONY's Avatar
Go for it. I have a 162(now discontinued/1 inch longer towards the distributor)and love it!!! I run low 11's. Check my car out in readers rides. Good luck!!!
Anthony
WHITE 84Z28-UPDATED{LOOKS LIKE 92Z28}.040 350W/MODS{B&M 162 UNDERHOOD BLOWER}TH350 TRANS.TCI 10",3:89 9" REAR,BLACKJACK SHORTIES HEADERS,SINGLE 3" EXHAUST W/ SINGLE OUT FLOWMASTER,BOXED R. CONTROL ARMS,RR AIR BAG,STEVE SPOHN ADJ.TORQUE-ARM,CUSTOM 6-POINT ROLL BAR,PRO-STAR RIMS,E.T.STREETS. BEST ET SO FAR{STILL HAVE SOME FINE TUNING TO DO} 11.51/118 1.61 60FT.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
JSDaddy189
Sep 26, 2015 03:50 PM
