Nitrous Preparations
Old Jun 7, 2001 | 01:41 PM
Black91GTA's Avatar
Hello, I want to run nitrous on my '91 GTA 350. Which kit should I get the NOS one or the Nitrous Express one? Also what else do I need to run nitrous? AFPR? MSD? Timing Retard? Etc. Thanks
1991 GTA 350 Black w/ black leather. 82k miles. Stock!
1988 IRoc 350 B&M Shifter, Dynomax exhaust, MSD Ign. Airfoil, K&N's (For Sale!!!)
Old Jun 7, 2001 | 05:25 PM
MouseCamaro305's Avatar
I'd say whichever brand you can find for cheaper, both are great systems and well made, NOS is more commonly used so it's easier to locally find parts for, but what you will need is a good working ignition-not nessecarely upgraded, stock works well too, stock fuel pump is adequate, I'd reccomend a nitrous and fuel pressure gauges, new plugs, cap, rotor and new wires, new fuel filter. thats about it, you can run up to 150 HP shot on a 350 without harming it, NOS doesnt make any reccomendations to retard the timing at all, but I would use this rule of thumb to be on the safe side: 1 degree retard per 50 HP gain. hope this helps a little and good luck. Let me know if you have any other questions
Old Jun 7, 2001 | 07:58 PM
JucinGTA's Avatar
NOS is Junk my friend, NX has a nozzle system instead of a plate system!! did you know that on NOS EFI plate system, they dont reach the first 2 cylnders!!! NX is the best, I had a bone stock 305, and was shooting a 150 shot it held up fine, I would though atleast recommend the AFPR and the Nitrous gauge, because the reason a engine blows up from nitrous is because the bottle pressures not right, and it is too lean and can seep threw the rings causing detonation below the rings!!!!
Old Jun 7, 2001 | 10:06 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Where can you get NX kits??
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
www.geocities.com/irocnroll90
Old Jun 8, 2001 | 07:50 AM
NavyVette's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JucinGTA:
NOS is Junk my friend, NX has a nozzle system instead of a plate system!! NX is the best</font>
That's weird I have a NOS fogger nozzle system on my TPI. I like the NX systems better also but I couldn't pass up a complete setup for $150.
Jeff
Old Jun 9, 2001 | 01:18 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I personally wouldn't buy the NOS system again but I do like the spray bar behind the throttle body. My advice is get a system with a spray plate but not nos. Also, I put in a hobbs switch to kill the juice if my fuel pressure drops, a clutch switch (where applicable), and of course the micro thr. switch. I also pulled 5 degrees of timing with my msd digital 6. I just ran a 12.44 @114 so the spray is worth it. Email me if you have specifics
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
14.0 at 100 NA before heads
Juice and AFRs??......TBD
New g-tech time without juice 13.46 at 108.8
anesthes
Sep 18, 2015 12:34 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
g.l.mos
Aug 22, 2015 12:02 AM
