Idea for a fade-in nitro
Old Jun 11, 2001 | 11:35 PM
One Eyed Jack's Avatar
Why not have nitrous start at 0 and rise to lets say a 100 shot by RPM? So as not to blow the engine? My friend tried a 225 shot on his 67 (?) stang and all 8 spark plugs EXPLODED.
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 12, 2001 | 01:25 AM
Bobalos's Avatar
It is called a progressive nitrous controller.
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old Jun 12, 2001 | 08:06 AM
Formula-91's Avatar
There are time based progressive controllers, and Jacobs makes an rpm based unit.
Old Jun 13, 2001 | 11:16 AM
Bobalos's Avatar
One cheater way to get a small "lag" is to put the solenoids up on the front radiator core support. this will give you a lag of the hit, but not a reduction or progressive hit. we used to do this quite a bit "in the old days" so that you did not smoke the tires out of the hole. we also used to put the Fuel solenoid "close" to the plate & the NOS solenoid "far" from the plate & play with the lengths of tubing to change how it hit. this is labor intensive & somewhat cost prohibitive, but it served its purpose & keeps things simple @ the pilots chair.
BW
Bobalos
aka Bob W.
Old Jun 14, 2001 | 08:59 AM
Mark W. Winning's Avatar
The progressive kits are a good idea, but think about this, how does it work??? It cycles the solinoids open and closed to limit spray. How hard is that on the solinoids!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jun 15, 2001 | 11:59 AM
craiger's Avatar
True that cycling causes wear on the cylinoids, however, titrating the nitro in to the motor puts less stress on the internals. cylinoids are cheap and easy to rebuild. And when you titrate the nitro in to the motor, you'r able to get more traction. I ran mid 12's before i had my progressive timmer and ran a 11.8 after i got the controller! After i rebuilt the motor, i ran a 10.15 with out the gas...got flagged because of no drive shaft loop/rollcage
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
