N2O & Alcohol injection
Old Jun 15, 2001 | 09:58 AM
mefreema's Avatar
Has anyone ever played with N2O & Alcohol injection. If so what is the best way to set it up and what are the benifits? With this setup are you less prone to detination? Also would you have to change jetting or fuel pressure to compesate for the use of alcohol as opposed to gas? Will a gas fuel solinoid be ok to use with alcohol? Finally would you use a rubbing alcohol?
Old Jun 16, 2001 | 01:24 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i use alcohol on my car it does help curb detonation by adding 10 points to the octain and cools the intake charge
i use alcohol frome a performance shop that sells race gas
i would not use rubing alcohol
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
BAMiller
Sep 14, 2015 06:38 PM
TheExaminer
Sep 6, 2015 11:40 PM
