MSD Ignition....
Old Jun 24, 2001 | 11:53 PM
CAMARO82's Avatar
MSD Ignition....
How much of a preformance difference if I change from HEI to MSD Ignition, With the coil and all that stuff? Thanks
Old Jun 25, 2001 | 12:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't really replace the HEI with the MSD, they work together. If your engine is stock you won't notice any difference. You'll only see a change if you have high compression or run at high RPM.
Old Jun 25, 2001 | 05:39 PM
CAMARO82's Avatar
I have a high preformance 350, the MSD package comes with the coil and The Soft Touch(to keep from overreving). Im pretty sure I have high compression Pistons. So Should I see a difference?
Old Jun 25, 2001 | 07:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
My car has had an MSD as long as I've owned it. I've never taken it off to compare, but you might notice easier starting, smoother idle and high-RPM operation. Maybe a tiny bit of improvement in mileage and power.
Old Jun 25, 2001 | 10:44 PM
CAMARO82's Avatar
<<This kit solves the common problem of power loss and lack of response above 4,500 rpm. It allows you to remove or bypass the low powered HEI module and coil and replace them with the 6AL ignition control and Blaster 2 high output coil. The result is more power, increased rpm range, easier starting, plus better mileage and performance. The kit fits all GM V8 engines with the GM HEI internal coil distributor and includes an MSD 6AL ignition with Soft Touch rev control to protect your engine from overreving, Blaster 2 coil, coil wire, HEI dust cover and coil bracket.>> This is what it said about the super Hei kit the one I was thinking about getting, SOund like a good deal? Its for 244.95 for the whole kit. Thanks
Old Jun 25, 2001 | 10:45 PM
CAMARO82's Avatar
This kit solves the common problem of power loss and lack of response above 4,500 rpm. It allows you to remove or bypass the low powered HEI module and coil and replace them with the 6AL ignition control and Blaster 2 high output coil. The result is more power, increased rpm range, easier starting, plus better mileage and performance. The kit fits all GM V8 engines with the GM HEI internal coil distributor and includes an MSD 6AL ignition with Soft Touch rev control to protect your engine from overreving, Blaster 2 coil, coil wire, HEI dust cover and coil bracket. This is what it said about the super Hei kit the one I was thinking about getting, SOund like a good deal? Its for 244.95 for the whole kit. Thanks
[/B][/QUOTE]
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
