I hooked up my new NX it and it worked for about...
Old Jul 8, 2001 | 10:28 PM
MATEOZ28's Avatar
10 minutes. Well it only purged while it was sitting. But it stopped purging and doesnt activate at all. Any suggestions?
Old Jul 9, 2001 | 12:14 AM
crazeinc's Avatar
fill up the bottle?
sorry I had to...
Old Jul 9, 2001 | 12:30 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Do you have a fuel pressure safety switch? If so, have you checked it?
Can you hear the solenoids click when the system is activated?
If not, have you checked the wiring with a volt meter at the solenoids to see if they are getting power? If they are not, work your way back through the wiring to find the problem.
If they are getting power then check their ground path.
If they are clicking when activated, is the bottle valve open all the way and does the bottle have pressurized nitrous in it?
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited July 08, 2001).]
Old Jul 9, 2001 | 12:07 PM
MATEOZ28's Avatar
I can hear the silinods activate. I do have a bottle pressure safety switch. My pressure is reading 1100psi. Will that cause the bottle heater to not come on?
Old Jul 9, 2001 | 09:39 PM
IROCKZ4me's Avatar
If the fuel and nitrous solenoids both click and the purge solenoid does too then the wiring is ok.
Since you have that much bottle pressure then more than enough nitrous is available at the bottle.
Check the main nitrous hose for kinks, pinching or something plugging them. With the bottle valve closed, remove the hose from the solenoid. Secure it so it doesn't whip around, or have someone carefully hold it with a gloved hand pointing it away from everyone. Crack the valve to see if nitrous comes out. (You did this durring initial installation to flush the hose right?) If nitrous comes out strongly then you are good up to there. Did you install a nitrous filter? Have you checked it to be sure it isn't plugged? What did you use to seal the pipe threads in the system? Could it be plugging the solenoids?
The bottle heater won't turn on at that high of a bottle pressure if it is a Nitrous express heater and control.
The NX control turns the heater on at pressures below 900 PSI and it turns off at 1050 PSI.
[This message has been edited by IROCKZ4me (edited July 09, 2001).]
Old Jul 9, 2001 | 09:41 PM
IROCKZ4me's Avatar
Oh yeah, make sure both the fuel and nitrous solenoids are both activating.
Reddeath210
Oct 6, 2015 08:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
stalkier
Aug 7, 2015 04:49 AM
