Should I upgrade my fuel system?
Old Jul 22, 2001 | 06:42 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I have a stock fuel system on my car right now with the Paxton(later some nitrous). I was wondering if it would be a good idea to upgrade it even if there doesn't seem to be any problems? How should I upgrade it inline fuel pump,bigger injectors,etc.?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Paxton SN92 Supercharger
Old Jul 23, 2001 | 01:09 AM
MouseCamaro305's Avatar
if youre going to be using nitrous soon l would definately reccomend you upgrade it, you should probably move up in injector sizes, you should probably also use a larger fuel pump and youll need an adjustable fuel pressure regulator. when you use the nitrous system (if youve got a TPI) most systems namely the one by NOS uses the wet technique which enrichens the mixture through the test port on the fuel rail. don't let that mislead you into thinking youve still got enough fuel. the most important fuel upgrade you do would be the pump and adjustable regulator. the pump obviously won't do you much good without a good adjustable regulator. people all have their different opinions as to which injectors would be good to use. If it was me I would probably use a cheaper brand of #24's (Accel, or even the Ford injectors) are pretty cheap and as far as I'm concerned they would do a fine job.
good luck and have fun
Old Jul 23, 2001 | 08:59 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
When you say add a bigger pump, should I just add a better intank pump or add an inline pump to aid my stock intank pump?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Old Jul 23, 2001 | 11:10 PM
l'd say either one. its really up to you what you want to do. if it was me i would do it the right (and coincidentally hard) way and replace the in tank pump. thats only because l have access to a lift. either way it would be good, but if its a matter of ease, go for the in line pump.
have fun and good luck
Old Jul 24, 2001 | 06:32 AM
PROCHARGED89Z's Avatar
A big intank should do just about anything you throw at it.Walbro GSS340M flows enough to support up to 600hp,I run this pump in my car with 50lb injectors.No problems yet.It cost me $110 for the pump and $10 for installation kit.Pump is plug and play in the intank sender very easy to replace.
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
