quik ? for Jester on serpintine
Old Aug 1, 2001 | 08:10 PM
superiroc's Avatar
How did you take apart the tensioner and reverse its pull? Thanks Matt
Old Aug 1, 2001 | 09:28 PM
Jester's Avatar
DISCLAIMER: This information is for entertainment purposes only. Do not try this at home as you may put your eye out
Now..the tentioner is very simple...only about 5 parts including the pully. The main body is 2 pieces, the spring inside, and a clip on the front holding it together. Mark where it is before you pull it off the engine, and where you need to rotate it to. Put the lower half in a vice, and pop the clip off with a long screwdriver ot tire iron. Wear eye protection. Put the spring and top half of the main body back into place. Wind the spring and top body to preload it whereever you want it. the clip will go back on every 90 degrees, and had a certain range of motion to allow for belt strech.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Aug 1, 2001 | 09:37 PM
superiroc's Avatar
thanks that helps
Old May 6, 2006 | 01:56 PM
DucksChevy's Avatar
Car: '89 IROC-Z Convertible
Old thread, anyone try this recently?
There is a locating pin on the tensioner. Do you need to drill a new hole for the this pin?
05/08/06
I've disassembled the tensioner and reassembled with tension in the opposite direction.
I drilled a new hole for the locating pin. I found that the alternator will bolt in, in the smog pump location. I slotted the lower mounting hole from the smog pump mount. And shaved off some material to allow clearance for the fins on the alternator.
gixxer92
Apr 12, 2022 12:09 AM
ede
Carburetors
Oct 20, 2001 02:39 PM
FiReBReTHa
Car Audio
Aug 8, 2001 11:17 AM
SeanSullivan
Carburetors
Mar 19, 2001 12:49 PM
85F-body
Jan 17, 2001 09:40 PM
