ATTN:D1SC guys
Old Aug 6, 2001 | 04:25 PM
PROCHARGED89Z's Avatar
ATTN:D1SC guys
Hey guys,( I know only 2 others besides myself)I did anoter little mod to my system bracket thats seems to help out a bit.If you guys ever try to remove the blower,You know how much a PITA it is to get the bolts out beause the whole radiator stuff is in the way.Well I got some threaded rod,zinc plated,grade 5 and made my own studs.Bracket comes off like a charm.And I noticed when tightened down I notice the bracket is noticably stiffer.Well It isnt much but I like to experiment with little crap here and there.
so Maniacc,I hear good news about your system.Hoe many cars you embarresed to date?Track times comming soon.Willie too whats up.
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Aug 6, 2001 | 05:16 PM
maniacc's Avatar
Darren,
Yeppers, the car is running GREAT!!!
So far i've whoop'ed on 2 ram air T/A's, a camaro SS, 2 camaro Z28's, 2000 mustang GT, and a 69 mach1...don't get me wrong though, these cars all took me off the line, but about half way thru 2nd gear i'd catch'em and start pulling on them...DAMN, WHAT A RUSH!!!
I'm trying too get things ready to go to the track, probably the end of Aug. sometime
I received a E-mail from Dorain @ ATI, hes gonna have the new crank spacers made up soon, plus i need a new belt, mines starting to seperate from popping off the pulley all them times...
I like the stud idea, but what about the bolt going thru the alt bracket???
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
Old Aug 6, 2001 | 07:35 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Darren,
Not much happening around here. Still using my car daily.... hey, it gets me from here to there and it's dependable too!!
Larry,
Now that you need a new belt, how about I sell you a 3.70" pulley and 64.5" belt to go with it...cheap!!! MORE POWER!!!
Willie
Old Aug 6, 2001 | 08:18 PM
maniacc's Avatar
Willie,
I really don't think my 60,000 mile motor will handle much more than the 10#'s boost it's already gettin' !!!
But hey maybe when i start building the new motor i'll see just how much the stock head gaskets can really hold
I've really been contemplating getting that new hood, I'm sure that it would be a big improvement on my intake temps...I've been seeing in the 140 degree range...HOT,HOT,HOT!!!
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
[This message has been edited by maniacc (edited August 06, 2001).]
Old Aug 6, 2001 | 09:34 PM
Willie's Avatar
Larry,
I thought you'd say that about your stock-bottomed engine. But before jumping to conclusions, talk to Dorian. I was quite surprised when I did about this (a stock-bottomed engine that is) and he told me without hesitation that it could hold up to 12 pounds of boost easily. Give him a jingle sometime.
My latest project incorporates my hood. I bought three digital air temperature gauges. They will be mounted in the cowl opening on one side and covered by a piece of smoked plexiglass (so you can't see the gauges themselves, only the readouts). They will give me air temperatures in the ducting
Before the intercooler,
After the intercooler, and
In the plenum.
I'll be able to monitor how effective the intercooler and water injection are by watching these three gauges. Should be interesting.
Willie
Old Aug 7, 2001 | 01:51 AM
89ProchargedROC's Avatar
a good running motor will handle 12psi. i had a 12psi pulley making 12psi @ 5500rpm and it handled it fine. i even went lean a decent amount of times due to a failing fuel pump (in tank) and it was still ok
Old Aug 7, 2001 | 05:51 AM
<font face="Verdana, Arial" size="2">Originally posted by maniacc:
Darren,
later
larry
</font>
Thats great Larry.I forgot to mention because I used that ill thread bolt many years ago from my P600B kit,It had stripped the threads out of my bracket behind the altinator.I juast drilled out the threads and run a stud threw it also.My car will be running on the street in the next 2 weeks.Having my new ypipe welded together as we speak.This is it.Already started the car,runs great,but my blower pully was off because of my crank trigger.Dorian is cutting down mine and I should get it today.
What do you guys think of the D1SCs?I been reading alot of crap over at the corral about the SC models and how they leak,and or seep oil.I have spun mine with my drill and dont see a drop,or it being on the car it doesnt seep.Anything with yours?
Old Aug 7, 2001 | 07:47 AM
Willie's Avatar
Not one drip out of mine.
Willie
Old Aug 7, 2001 | 05:07 PM
maniacc's Avatar
Mine's seeping alittle, i get a small film on the bottom side...oil level is still o.k. though, i'll have mine off after next week to change the oil and replace the belt and hopefully the crankspacer...
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
