NOS leaking.....please help
Subscribe
Aug 10, 2001 | 12:02 AM
I bought a used a NX kit and everything seems to work fine except 3 things
1. The shark nozzle leaks nitrous *Barely drizzles out*
2. The fuel doesnt seem to shoot out of the shark
3. I accidently wired the purge wrong and the sylinoid burned up from overheating.
Can I have the purge syliniod rebuilt?
Why is the nos leaking?
I would imagine the nos is leaking out of the sylinoid but how do I stop it?
I have a fuel pressure safety switch would this cause the fuel not to shoot out while the car is at idle? Thanks
Reply 0
Aug 10, 2001 | 02:37 PM
You should probably go back and double check all of your wiring! If you wired the safety switch corectly neither the fuel or nitrous solenoid shoud hit if the pressure switch is breaking the current. The switch is adjustable, make sure it is adjusted correctly. Use a volt/ohm meter to check if the solenoids are getting voltage. Use the ohm meter to check the solenoids for continuity.
The nitrous solenoid needs rebuilt if it is leaking. The purge solenoid needs replaced if the coil is burned up. You can check that with an ohm meter.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Reply 0
Subscribe
