AIR-Supercharger
Old Aug 9, 2001 | 10:30 PM
breathment's Avatar
AIR-Supercharger
just curious how much flow the AIR system flows, like how much PSI, but i seriously doubt there is anyway to use this as a ghetto super charger is there?
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 10, 2001 | 02:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, but if you're desperate to use it for something, you can turn it into a crankcase evacuation pump.
Old Aug 11, 2001 | 12:10 AM
breathment's Avatar
well i was just curious how much AIR it actualy pumped. heres another question, if i removed the hose that goes to the manifolds from the air pump, will any exhaust gas come out of it, if so then wont it be loud? or is the hole to small? i know stupid questions.
Old Aug 11, 2001 | 01:19 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
if you disconnected the air hoses youd have whats sounds like a deep sounding vaccum leak coming from the pump on the manifoldss ther are 1 way check valves that keep the exhaust from reverting back through it
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,new springs,aluminum driveshaft.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
anyonne from new jersey interested??????
