LT1 383 list
Old Aug 14, 2001 | 09:24 PM
Electromaro's Avatar
LT1 383 list
what would i need to get to change my stock 97 lt1 into a 383 stroker. also, would this be good for an everyday car? i have a t-56 and jasper 3.73 posi.
Old Aug 15, 2001 | 09:00 AM
ATOMonkey's Avatar
1 piece front and rear seal 383 crank(should be LT1 specific)
6 in. 383 rods(keeps the same rod angle as 5.7 in. rod with shorter stroke).
6 in. 383 pistons(pin is higher in the piston)
Relieve the block and rod bolts for clearance
While your in the machine shop it has to go .030 inches overbore to get 383 inches. Also pick up an engine rebuild kit.
Now that you've done all that you've bumped compression quite a bit. Look to retard timing and run high octane fuel. The top end of the engine should be able to support the extra air flow.
Am I missing anything?
Old Aug 15, 2001 | 09:42 AM
Blockhead's Avatar
<font face="Verdana, Arial" size="2">Am I missing anything? </font>
Yeah, go here for more information
www.turbofast.com.au/
Old Aug 15, 2001 | 12:16 PM
thanks guys. i love this board.
L0tuS
Oct 4, 2015 08:07 AM
Linson
Sep 21, 2015 01:08 PM
WickedBowtie
Sep 11, 2015 11:24 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
L0tuS
Sep 4, 2015 11:16 PM
