Which AFR heads and what cam?
Old Aug 16, 2001 | 05:33 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have a 406 motor that I want to make into a blower motor. I am looking at AFR heads but cannot decide between 195 and 210's.
I want to run a hydraulic roller cam and want to know which would be the best for the application.
It is a automatic car, 3000 stall, 4.11 gears, Procharger D-1, hoping for aorund 12-15 lbs. of boost.
Any comments are experiences would be appreciated.
Steve
Old Aug 16, 2001 | 09:37 PM
Guido's Avatar
Car: 2000 Trans Am
Go with the 210. Possibly even the 220.
When you get a cam, call comp cams or cam motion and tell them your combo. They will be able to tell you better than anyone what cam you should run.
Check out my webpage. I have a 406 with an S-Trim Vortech and AFR190 on it. I want better heads then the 190.
-86 IROC
11.31 @ 120.2 mph
-=ICON Motorsports=-
Old Aug 16, 2001 | 10:14 PM
mtx28's Avatar
like guido said, the bigger heads. a 406, with 3000 stall, 4.11 gears, and a D1 is going to be one hefty motor. it sounds like its oging to want to make power in the high end, so get the 210s or 220's. i'd call afr, and after you decide that call comp cams or whoever. remember, a cam is more of a tuning aid than a way to make power.
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Aug 17, 2001 | 12:29 AM
Bobalos's Avatar
http://members3.boardhost.com/crg2/msg/21.html
Here is a deal even with shipping. I know the owner/car, if you want to know more, contact me via email.
BW
My new motto, buy more head than you can afford & worry about the rest later. if you dont have the best heads you can get, the rest is just stuff.
Old Aug 26, 2001 | 09:48 PM
Z28Express
Guest
Posts: n/a
Bobalos you are a smart man, heads = HP!!
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
michealleger
Aug 26, 2015 03:29 PM
hayesaw0210
Aug 23, 2015 11:15 PM
89mulletbird
Aug 12, 2015 07:08 PM
