The Best Blower Motor Combination
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
If you read my other post, you will know that i have just broken my bottem end in my 355. So, I have a block, Trick Flow Twised wedge 2.02's (66cc I think), Superam, 1000cfm tb, 26lb inj., Vortech S-Trim (10 and 15 lb pulleys) and that's about it. Now, what i want to do is a VERY cos efficient build up w/ my old block, or maybe even a new one. I'd like to stay w/ something LOW compression, so I can run 94 octane and 10-15lbs boost w/out any pinging/ detonation. I Want to stay NYS emmisions legal. I want to build a shortblock only. And again, I HAVE to stay real cheap like $1000 w/out the cam. I'm not sure what i can reuse out of my motor now, but we'll see when I get it apart. My questions are: considering what i have, what are some PROVEN combinations and ET's. What do you think I have to do, and how much will the work be w/ shortblock assembly and using as many old parts as possble? I want to go w/ something like he LPE 220 cam. Remember, emmsions, cost, durability, no pinging, pump gas and that i want to ust what i have. Suggestions please. I would like 383, but i guess for cost purposes, i have to stay 355 for now. please reply.
thanks------------------
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best ET (Nat. Asp.): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 -*100% NYS emissions legal*
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, Install completed 7/9/01: 10 & 15 LB. PULLEYS, HKS race bypass, Custom cold air, Swapped to serpentine. Best ET: High 11'S I Hope.
[This message has been edited by Justin 87 GTA (edited August 27, 2001).]
Street Lethal
Aug 13, 2015 08:28 PM
