compression ratio for nitrous
Old May 20, 2006 | 02:32 PM
acidpad's Avatar
Car: 1991 RS
Engine: 406 in progress
Transmission: th350
I'm building a 406 with all forged internals, 64cc heads, and was planning on running around a 10.8 ish compression ratio, and was wondering if I would be able to get away with about a 250 shot of nitrous. My cam has the following profile
Cam Style: Mechanical flat tappet
Basic Operating RPM Range: 2,800-7,200 RPM
Intake Duration at 050 inch Lift: 252
Exhaust Duration at 050 inch Lift: 260
Duration at 050 inch Lift: 252 int./260 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 298
Advertised Duration: 290 int./298 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.558 exh. lift
Lobe Separation (degrees): 110
I'll either run it on pump premium, or find some higher octane race fuel (I know I have something around here somewhere).
Old May 21, 2006 | 12:36 PM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
nobody knows what the max CR i can have to run nitrous on a cam with those specs ?
Old May 21, 2006 | 12:41 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Not sure about the cam, but nitrous loves compression.
My friend ran 250shot on his 11:1 385 forged LT1.
I'd use studs to hold the heads on vs regular head bolts.
Old May 21, 2006 | 11:12 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i am running 13.9 compression on my 408. on a 150 shot i gained 198 rwhp on the dyno. you just have to make sure you run race gas to prevent detonation. i run straight sunocco 110.
Old May 22, 2006 | 12:13 AM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
great information, I really appreciate it. Wont be afraid to run the 11:1 then.
Old May 23, 2006 | 05:34 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I'm on a 10.5 to 1 406 with a 200 shot. Worrks perfectly for me, never had a problem.
Old May 23, 2006 | 05:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Sorry to hi-jack, but............
What are you 400ci+ guys running for head gaskets? Are those GM blocks?
Old May 23, 2006 | 09:12 PM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
still working the whole head gasket thing out ....
Old May 23, 2006 | 11:40 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
ii have a dart block and heads. and felpro performance head gaskets. never had a problem. use to run 11 to 1 and a 350 shot with the same gaskets
Old May 24, 2006 | 03:10 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
I'm running a dart little M block with Dart pro 1 heads, I thing the head geskets I used were felpro 1014's if I rember correctly.
Old May 24, 2006 | 07:29 PM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Run a lower CR...like 10:1 or so. Then you can run pump gas. higher CR will require race gas. I know folks who run 11:1 CR's and have to run race gas on the 150 shot...weak. I run a stockish 9:5 CR and urn 93 octane with al il more itming and no detonation problems.
10:1, 93 octane, pull osme itming and spray and pray!
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
