N20 Safety
Old Sep 9, 2001 | 11:02 PM
FCamaro's Avatar
N20 Safety
I was wondering with NOS if you get into an accident will there be an extra danger present with a full bottle in your car? Is there any chance of it exploding, causing fires, etc.
Old Sep 10, 2001 | 02:43 AM
Jester's Avatar
Nitrous isn't flammable. However, a physical rupture in a cylinder containing 3000psi of anything is very, very ugly. I've seen pics where it happened..the entire back half of the car just about was shredded. The garage door behind it was toast to, in one series I saw of a Maxima that left his bottle heater on.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Sep 10, 2001 | 06:59 PM
FCamaro's Avatar
Old Sep 10, 2001 | 11:53 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
There is very little risk, however there is a chance of a serious problem occuring.
the bottle is very strong and is not very easy to rupture in an accident, but a particularly nasty and extremely hard hit could possibly bust it. A little more likely though the valve could be broken off and the nitrous could escape the bottle. If the bottle isn't bolted down well and the valve is broken off the bottle could become a missile.
Nitrous is a cryogenic gas. Anyone close to the valve durring a rapid discharge could suffer from frostbite.
Without ventilation after a discharge inside of the car passengers could be asphixiated.
While nitrous itself is not flammable it is a powerful oxidizer.
This means it will accelerate the combustion of flammable materials.
Given these worst case scenerios, yes nitrous can be dangerous. Given common sense and safe handling it is relatively safe though.
If in doubt about it don't drive around with the bottle in the car unless you intend to use it.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Sep 11, 2001 | 04:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by IROCKZ4me:
</font>
Only if the right conditions are present for decomposition of nitrous oxide.
Old Sep 12, 2001 | 03:58 AM
IROCKZ4me's Avatar
That is correct, it would take extreme heat to seperate the nitrogen and oxygen, or the interaction of another element to liberate the oxygen.
MM2Robinson
Oct 1, 2017 09:16 AM
Nervous2
Oct 8, 2015 10:53 PM
Buickstaged
Interior Parts Wanted
Oct 4, 2015 11:49 AM
PeteK825
Sep 22, 2015 10:47 AM
WhteRbt
Sep 21, 2015 09:48 AM
