anyone have proof?
Old Sep 4, 2001 | 10:39 AM
blowen90ta's Avatar
anyone have proof?
that a larger than stock 48mm tb actually helps increase airflow on a supercharged 350?
i inderstand maybe intil the boost takes over it could help a little but are they worth the 300 they cost?
thanks
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger,afr heads, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Sep 5, 2001 | 12:28 PM
89ProchargedROC's Avatar
Just think about the engine being a garden hose with the exhaust being outlet, the motor being the hose, and the Throttle body being the inlet
If you have a BIG hose and a BIG outlet and SMALL inlet....you wont be flowing as much air as you could
A motor is just a big air pump. the faster you can get air in/out the more power you will make
thats why exhaust and intake are the power making on blown cars....you can get away with a stock cam and crappy heads....but exhaust and intake have to be up to par
Old Sep 5, 2001 | 03:21 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Tell it brother! Preach the word of Forced Induction!
<font face="Verdana, Arial" size="2">Just think about the engine being a garden hose with the exhaust being outlet, the motor being the hose, and the Throttle body being the inlet
thats why exhaust and intake are the power making on blown cars....you can get away with a stock cam and crappy heads....but exhaust and intake have to be up to par.
</font>
I dont think I could've said it better myself.
Old Sep 5, 2001 | 08:33 PM
<font face="Verdana, Arial" size="2">Originally posted by JAYDUBB:
</font>
I do what i can
Old Sep 7, 2001 | 08:10 PM
blowen90ta's Avatar
thanks for the reply but i asked for proof that a larger tb actually provides gains on a centrifical supercharged car seems that if you are reading 9 lb boost at 5500rpm with a 48mm and the only restricton being heads valves and intake passages and exaust how much if any pressure is lost at the tb. seems the only way to measure this is a gauge on each side and record the diff or track results with the tb being the only change.
theory is great but any real results?
Old Sep 7, 2001 | 10:19 PM
With a TPI setup i dont think you will see a HUGE gain because the intake is so restrictive as it is
BUT
put a larger base or miniram on and you'd definately see a result
Old Sep 8, 2001 | 11:51 AM
blowen90ta's Avatar
here is what i have a ported plenum,asm ltr's and an edelbrock manifold that were extrude honed.thinking of a bigger tb but think it most likely a waste of money for the gain
thanks for the replys
Old Sep 15, 2001 | 11:39 AM
86 IROC's Avatar
I put a 52mm TB on my old NA 350 TPI, got .2 w/o any other changes. I'm sure that w/ a SC you will notice a gain worthy of the $300 spent.
13.248 @ 101.74 w/o 52mm TB
13.042 @ 102.24 w/ 52mm TB
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Sep 20, 2001 | 08:42 AM
blowen90ta's Avatar
ok so should i go with a 52 or 58mm ?
Thirdgen89GTA
Nov 26, 2015 11:04 PM
69 Six Pack
Oct 5, 2015 07:51 PM
NBrehm
Aug 5, 2015 07:57 PM
JPrevost
Carburetors
Nov 12, 2001 06:28 PM
Mike86Z28
Sep 24, 2000 10:22 PM
