Injector Size!?!?!?!
Old Nov 5, 2001 | 11:55 AM
Tom Simpson's Avatar
I'm going nuts...everyone says something different.
Right now I'm running a mildly worked 350 tpi and 10 lbs of boost on an s-trim. I have the fuel pressure at 42 psi on 30 lb injectors with the timing advanced and its still rich as hell......a few people are telling me its too much injector and a ton of people tell me im stupid for wanting to step down in injector size......
The past archives on here havent helped much either. Has anyone other than willie ran smaller sized injectors?
Tom
Old Nov 5, 2001 | 03:00 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You could do some custom prom tuning and make those 30lb injectors work right in your system.
Modify the injector constant then tune with a scantool; it's an iterative process.
Old Nov 5, 2001 | 05:48 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I second that.
Your injector size is fine.
You just need to control them better. A custom PROM tune is in order. You didn't say if you had a PROM that is calibrated to the stock injectors or to your new ones. If it is indeed calibrated for stock sized injectors then it will most definately run rich with larger than stock injectors.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
