NOS 5151 Problem with plate and idle....
Old Nov 14, 2001 | 06:14 PM
86IROC305's Avatar
I just put on a 5151 kit last weekend and everthing works fine, except the NOS plate won't allow it to return to the fully closed position. The added space makes constant tension on the gas cable and wont fully close even with a return spring. Anyone else have this problem ? Is it possible to adjust the cable length?
86 TPI 305 Iroc-Z
WC 5spd
9 Bolt Rear Disc Swap w/ 3.45's
Accel HEI SuperCoil
MSD 6AL
NOS 5151
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Nov 14, 2001 | 10:29 PM
Omar's Avatar
You know how the stock bracket attaches to the plenum and holds all the cables (TV, accelerator, cruise)? Well, did you install the NOS piece inbetween the plenum and the stock bracket the moves everything forward to accomodate the changes made by the plate?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
[This message has been edited by Omar (edited November 14, 2001).]
Old Nov 14, 2001 | 11:49 PM
86IROC305's Avatar
When in doubt RTFM! I left out that piece (Woops! ) and realised my mistake shortly after I posted. Everything works great now, so off to the track tommorow!
86 TPI 305 Iroc-Z
WC 5spd
Accel HEI SuperCoil
MSD 6AL
NOS 5151
Comp Cams 260H-12
Old Nov 15, 2001 | 12:34 AM
Kandied91z's Avatar
post some times on and off the juice.
as well as what jets your running.
have fun.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
someone972
Aug 30, 2015 12:52 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
