removal of a/c & smog pump results
Old Nov 29, 2001 | 05:10 PM
89formula4life's Avatar
what would the results be if i removed the ac off my serpint belt system?? more horsepower?? and same goes for the smog pump.. would removing this mess up the computer or anything on my 89 formula 5.0 TBI??
Old Nov 30, 2001 | 12:18 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Research that I read is that the smog pump takes about 4HP. Yes, that's it. 4HP. And the newer ones take even less.
You won't see an appreciable gain from removing your AC either, unless you're using it when you are stomping on the power.
The gain you'll really see from removing AC and smog is accessibility to your engine. If you can live without a/c and work on your engine a lot, go ahead and remove it.
Old Nov 30, 2001 | 07:54 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I removed the A/C and smog pump from my '85 Z28 (much easier with a v-belt setup.) I did notice a slight hp gain, however the accessability gained in the engine compartment was significant! That also got rid of alot of dead weight under the hood.
'91 Camaro RS - TBI 305 - medium garnet - '91-'92 Z28 wheels - leather - all power options (except power seat) - t-tops - Clarion head unit - Pioneer 4way 200watt 6x9s - Rockford Fosgate Punch amp and 2 Fosgate 12" subs - Edelbrock open element w/ K&N filter - Random Technology highflow cat - some free mods, more coming soon...
[This message has been edited by RSFreak (edited November 30, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
