Best intake for a supercharger...
Old Dec 2, 2001 | 06:58 PM
BadBowtie88's Avatar
I am rebuilding my 350 Iroc next summer. If I do supercharge it, what is the best intake for this? Any help is appreciated.
1988 Iroc-Z
L98 350 TPI
700R4 Tranny
2.77 gears
Mods: Crane CompuCam, headers, gutted air boxes, aluminium vette heads
Best e.t.: 14.20@96.97 mph
60ft.@2.17
Old Dec 3, 2001 | 06:58 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The better flowing the intake is the better it will be.
You can use them and make good power, but you don't need the long indpendant runners like a stock TPI.
The supercharer will make more than enough torque with short runners and will make more horsepower too.
A short runner manifold like a mini ram will work very well probably making the most power, if you want to stay with somethig a little closer to stock configuration a super ram will be fine. Or for an even more "original type configuration", you can also use a stock ported plenum with deeply siamesed runners and/or siamesed base too.
You can use all stock type components with good results too. Especially so if ported. Boost helps make up a little for intake manifold short comings.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Dec 5, 2001 | 01:21 PM
Amrish's Avatar
All i can say is D1SC w/ 3-core intercooler
1992 z28 25th Anniversary
All black w/ z28 wing
Flowmaster Exhaust
350 TPI
Check out my car!
Old Dec 5, 2001 | 04:27 PM
89ProchargedROC's Avatar
a shorter runner intake will usually make more hp at a LOWER boost reading with the right cam
where as a longer runner intake will make the same hp as the short runner, BUT at a higer boost reading because you have to really push the boost through the long runners, again matched to the right cam
point in case:
local 88GTA that went 10.80s on 17psi with a 383 and STOCK base, runners.
if he had a miniram he'd probably hit the same number with about 12-13psi all things being equal with suspension/cam/converter/gear selection
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
