Heat soak
Old Jun 9, 2006 | 11:35 AM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
Heat soak
Dont know if this is the right board for this, but I am having some mean heat soak issues (TB mounted k&n too). Just wondering if you guys have come up with any creative ideas to dissipate heat in engine bay. doesnt have to look pretty.
Ive seen the two tech articles on CAI's already. Is there any other ways to make one?
I put this in power adder because cold air = more power
Old Jun 9, 2006 | 06:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
huh?
nah, this is more of a tech general engine question, this forum is for forced induction, superchargers, turbos, N2O.
2nd, what do you mean heat soak? You mean you want a cold air intake, or your starter won't start the car after the car is hot, due to heat soak?
Old Jun 9, 2006 | 11:18 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
who said anything about a starter?
Im saying that my engine bay gets really hot and its hurting performance. i need better cooling solutions
Old Jun 10, 2006 | 01:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
ah, ok, the term heat soak is usually paired with a starter.
do you have headers? having them coated is the biggest thing, header cause a ton more heat.
Otherwise, there isn't much you can do to keep your engine bay cool, short of cutting a new grill in your front end, or fabbing the trans-am air vents into your quarter panels.
TBI motor? best way for a CAI is a cowl induction hood, or a bolt on cowl induction onto your stock hood, and use an open element air cleaner, and seal the air cleaner to your hood.
Old Jun 10, 2006 | 04:02 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
TPI motor.
its in my specs under the avatar.
I did just get headers.
what is cheaper, wrapped or coated?
Old Jun 10, 2006 | 06:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
actually, the wrap is more expensive then I thought it was, but it's still cheaper I think. The wrap is not a good idea though, it holds in moisture, and makes it rust faster, and looks like crap.
Get 'em ceramic coated, it looks like chrome, and reduces the temp a lot.
Old Jun 11, 2006 | 09:52 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
TB mounted K&N is a power reducer. Mounting it that way is only good for doing a quick setup to get an engine running. The coolant fan blows hot air into it. Use some 3" pipe to the front of the fender well with the K&N or go back to the stock setup which was better than what you have now.
Yup, typically about 1% HP per 10*F drop. It all depends on the application.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
