tbi nitrous
Old Jun 16, 2006 | 10:34 PM
sp63
Guest
Posts: n/a
tbi nitrous
so i was looking through a summit catalog today and i was thinking about the deal on a tbi plate that fell through. and i found this:
and i got to thinking first off, would THAT work on my tbi with a big chrome air cleaner or would it spray into the top of the injectors..
then i got to thinking.. hmm fogger nozzles are only like 40 bucks... i could drill holes in MY air cleaners base like that and point nozzles into the butterflys. and i went further. edelbrock makes annular discharge nozzles. they shoot pretty straight. i could have them pointing pretty much down into the butterflys without impedeing on the injectors flow cone. i figure... 2 nozzles, a 50 shot setup in each one, this would feed a 50 shot to both banks equallly. right?
so i got to thinking. let me ask around. a friend said my intake is aluminum (stock 92 305 tbi) and that i can drill and tap it on the car and the aluminum wont hurt a thing in the engine. being soft and all. and it makes sense. he runs a company and says he drills and taps nitrous bosses / boost taps all the time. so would it be better to drill UNDER the tbi into the manifold on each bank roughly near where the two banks are in the uh.. open plenum are and have the nozzle there or shooting down the butterfly tract?
next thing..
beat to hell 150k mile 305. will it hold a 100 shot? if i use it properly , ie: above 3k rpms only...
Old Jun 17, 2006 | 05:25 AM
s10's Avatar
s10
Car: 88 s10 blazer
Axle/Gears: 4:10
nitrous works has a tbi plate kit
Old Jun 18, 2006 | 10:59 AM
sp63
Guest
Posts: n/a
yes BUT, i think if i install a plate it wont clear my hood. as of now the wingnut ontop of my air cleaner is THROUGH the padding, but not touching the hood yet...
Old Jun 18, 2006 | 11:27 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
put a drop base air cleaner on it and trim the stud coming out of the tb that holds the air cleaner. i know guys running a victor jr with drop base that fits under the stock hood. honestly, i'd buy something that works rather than screw around with a backyard nitrous system...and if a piece of that "soft" aluminum go into the oiling system and managed to get wedged between say a roller lifter and the cam...yeah, that could be bad. if your going to do drilling on the intake, take it off the motor.
Old Jun 19, 2006 | 03:16 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
fogger plate is only /4" thick... Pointing a nozzle like that...I wouldn't try it...backfire would suck.
Old Jun 19, 2006 | 05:44 AM
sp63
Guest
Posts: n/a
how would it get into the oiling system?
it will fall into the runner. and go into the engine. aluminum is soft. so it wont hurt anything and go right out.
edit: is the plate cheap? cuz the fogger nozzle is only like 30 bucks.
Old Jun 19, 2006 | 09:49 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
The plate is NOT cheap I just looked into installing nitrous on my S10 and was debating spraying the fogger nozzle directly towards the TBI unit in the front (I already have the fogger nozzle and the plate ran in excess of 100 dollars!) I bought a Phenolic spacer as well to attempt to put the fogger nozzle in there, no dice the intake is a twin plane. I am probably just going to go with the fogger nozzle aimed at the TBI unit, cross my fingers and pray.
Old Jun 22, 2006 | 10:36 PM
sp63
Guest
Posts: n/a
well thats exactly what i wanted to do. think im gonna go ahead with it too.
Old Jun 23, 2006 | 07:18 PM
Another idea I had talked to a company who does throttle body mods about was installing a vacuum modulated fuel pressure regulator and running a Mustang style dry shot. If you get your wet shot done before me, write and tell me how it goes, if I beat you to it I'll be sure and keep you posted on how it works. PS I am installing a Holley Blue fuel pump inline with the factory pump to keep up with the fuel demand because they say the TBI pump will only flow enough to support around 300hp, you may want to consider upgrading pumps somehow.
Old Jun 23, 2006 | 09:57 PM
sp63
Guest
Posts: n/a
ive heard those inline pumps like that wont work right if the stock pump is still in place...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
