Remove power valve protector in carb blow through application?
Old Jun 21, 2006 | 03:18 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Is the removal of the power valve protector necessary for a blow through application?
I first noticed this on the following website: Blowthrough Carb How-To
Old Jun 21, 2006 | 03:30 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If you want the extra fuel to come from the power valve then it needs to be removed. If you want the extra fuel to come from the main jet then it does not need to be removed.
It depends on how you set up the carb. Another way to spray the boost fuel is to use a fuel injector that sprays via a Hobbs switch when under boost.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
