what exactly is a hybrid?
Old Jul 26, 2006 | 03:57 PM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
I know this sounds basic, but what specifically is a hybrid turbo??? I see it everywhere but I really dont know what it is. Such as a T3/T4 Turbocharger...Is it a T3 turbine housing with a T4 compressor or the other way or what??
Old Jul 26, 2006 | 04:24 PM
Crisis's Avatar
thats basicly what it is
Old Jul 26, 2006 | 06:13 PM
Car: 1990 Trans Am
Ok. Thats what I thought...But can any compressor or turbine sections from different t3s and t4s be put together and labeled a T3/T4 hybrid?
Old Jul 27, 2006 | 02:23 AM
Drac0nic's Avatar
A T3/T4 hybrid is usually a T3 turbine and a T4 compressor. This allows improved spooling compared to a T4 and improved top end compared to a T3. It's sort of a compromise, not to say it doesn't work VERY well if matched properly. These work well on 4/6 cylinders as a single and small-mid size V8s with a twin configuration, perhaps a single if your V8 were anemic enough (267, 305 etc) Building a hybrid turbo can be done with off the shelf parts with no modifications to the components, by a reputable dealer or hell you could build one yourself from parts and have it balanced.
I've seen some people selling T4 hot sides with T3 compressors; anyone selling a turbo like this is running a scam or is a moron, avoid at all costs if you value your money.
Old Jul 27, 2006 | 06:11 PM
Car: 1990 Trans Am
Thanks man. That helps a lot.
Old Jul 27, 2006 | 07:07 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I've seen them too. those are the left overparts when someone buys two turbos (a t3 and a t4) and makes a hybrid out of parts from each. unless they're re-balancing the shafts... neither of the mis-matched turbos are going to last long.
RaverRacerX
Mar 17, 2026 01:49 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
merlot-fro
Apr 11, 2015 10:28 AM
Gumby
Oct 6, 2005 01:05 PM
BretD 88GTA
Southern California Area
22
Apr 1, 2005 01:14 AM
