how big of an combustion chamber
Old Jul 26, 2006 | 09:17 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
i have a question, i'm about to buy a supercharger and a pair of heads for my car. well my question is do i buy a high combustion chamber heads like a high 70cc or a low like an 64cc chamber??
Old Jul 27, 2006 | 08:29 AM
roarin_mouse's Avatar
Car: Z-28
Engine: 383 stroker
Use whatever it takes to get your CR low enough to handle the boost pressure that you intend to use. If this is a stock bottom end, I would stay under 10psi and with a CR of 8.0:1 - 8.5:1. Other opinions will soon be coming but that's my two cents.
Old Jul 27, 2006 | 09:46 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
It depends on what pistons you have. The less dish on the pistons will require a larger cc on the heads to maintain a low compression ratio.
Old Jul 28, 2006 | 07:30 AM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
ok
well i have alum pistion but i have cast iron rods and crank. what about if i just change the crank to forge can i just increase the psi in the charger or will i have to change the pistions/rods to??
ttt
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
