Supercharger piece parts
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I have a 350 bored .060 over. It has Wiesco pistons Manley rods, and a Scat forged crank. The block is a 2 piece seal with 4 bolt mains with ARP hardware used throughout.
The heads are Pro Topline Vortecs IRON. I have had the intake ports opend up to almost 180CC and the Exhaust to 65CC. I am running 2.02 Intake valve and 1.60 Exhaust. The Cam is a XM262H Comp Grind
The intake consist of the SD Vortec TPI base. SLP heavily ported runners and a matched plenum.
I am running 30lb ford racing injectors, Pertronix ingnition box, and a holley Comander 950 EFI controller. With a custom electrical harness I made my self.
I am also running the biggest in tank walboro fuel pump available.
When I built the engine the idea was to supercharge it at some point, but it has been almost 2 years and I am still putsing around naturally aspirated.
I would like to run somewhere around 12-15 psi of boost.
My problem is, that most of the supercharger stuff I find, comes in kits. I am thinking with all the hardware that is on my car now. All I need are the head unit, brackets and intercooler. Intake tubing would be nice, but I have sources for that and can put something together if I need to.
SO I I am hoping I can save SOME money by only buying the parts I need. Does anyone know where I can by stuff ala carte?????
Car: 91 GTA
Engine: 377ci
Not really looking for used. I would like to either go online or call somebody up and request the correct parts to do achieve my goals. I would take a used system for the right price, but it would have to be in really good shape.
This is not a lack of money request. I just do not really need things, like an FMU, fuel pump, ignition box, Oil lines and fitting and so on.
The equipment on my car now will take care of those things.
LT1Formula
20
Nov 14, 2015 12:02 AM
toronto formula
Nov 10, 2015 06:17 AM
