nitrous ppl inside plz
Old Aug 19, 2006 | 05:48 PM
daves12secV6's Avatar
ok tom im heading out to the f-body nationals with my turbocharged v6 rs.ive gone a best of 12.6@112 on the turbo.The national street legal v6 f-body et record stands at 11.89(set by a supercharged/nitrous 4th gen 3.8).tom i am going to try to break this record.Since that 12.6 run(was on the speed limiter and didnt even know it,speed limiter is now disabled) i have droped about 400 pounds out of the car.and also installed a wet nitrous system 35-75 shot.
well my turbo takes a bit to spool in first gear due to my 4:10 rear gears.i can get about 7-9 psi on the line while staged but i soon as i launch and go about 10 ft i come out of boost.so my idea is to spray as i come off the line to spool the turbo.I will prolly spray all of first and 2nd gear.
now my question is should i spray as soon as i launch or should i wait till im down track a few ft,for u guys with automatics do u come off the spray on gear changes?any tips or suggestions would be greatly appreciated,ive only ever sed nitrous about 4 times before,and only down track in high gear on n/a engines
Old Aug 19, 2006 | 11:53 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Spray whenever traction permits.
Do you have a window switch?
That would work great for you, find out when you are hooking up and hit the spray.
I spray as soon as I hit WOT, using a 125 hp shot. I have good traction so far.
I am going to spray a 140 shot and may have to delay the shot till I get to 2500.
Good luck!
Old Aug 20, 2006 | 08:55 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
thought you shouldnt spray below 3k rpms?
Old Aug 21, 2006 | 07:50 AM
chikn305's Avatar
I have a TTA motor in my car and Im using a 75 shot to spool the turbo. I spray right out the hole and turn it off at the end of second. Last friday it ran 7.35 in the 1/8.
Old Aug 21, 2006 | 02:53 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Though I have a 350 TBI, I spray @ 10 mph, 2300 RPM, WOT. I can play with all these settings in the ecm, but this is when I have traction w/245/45 zr 17's
Old Aug 21, 2006 | 09:09 PM
Engine: LO3
how are you spraying at such a low rpm? i was told 3k is the lowest you should go could i start spraying mine at 2500?
Old Aug 21, 2006 | 10:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I've sprayed my truck at 2500 RPMs with no problems...
Old Aug 21, 2006 | 10:36 PM
Engine: LO3
well i dont want to blow my car up or have an intake backfire could i do it with my stockish 305 tbi?
Old Aug 22, 2006 | 04:47 AM
83 Crossfire TA's Avatar
Hey, everyone has the right to try blow up their engines, if the’re really getting spray into the engine that soon then they’ll likely do that the first time the pedal it to control traction, and even if they do not they will eventually hammer out the bearings and spin one.
Real world, I’d bet that in most cases they’re fairly safe… they all seem to have automatic transmissions and even with a stock converter and no spray I’ve been seeing 2300rpm stall speeds coming off the line, and I’d bet that I’m well over 3000rpm by the time I’m at WOT, so I don’t think I could actually trigger an N2O setup with a properly adjusted WOT switch on a dragstrip pass before 3000rpm…
Old Aug 22, 2006 | 05:28 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
With that small of a shot I would say you could spray it as soon as you went WOT regardless of what RPM you're at. I spray my stock 350 TPI with a 150 shot off the line foot brake stalling it to 2000rpm, since you're boosting on the line and losing it down the track you should be able to spray directly out of the hole before the car bogs.
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
