turbo or super?
Car: 89 Trans Am, 84 Firebird
Engine: 305 TBI
Transmission: 700 R4
turbo or super?
Im trying to add a little kick to my 89 Trans Am, and im trying to figure out if a turbo charger or supercharger. Also trying to see which one doesnt bring my mpg down much.brand names and links would help
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
honestly for the cost vs power, its not worth it with your tbi 305.
on your stock motor you will have to up the octane or get detonation. for boost you want a low compression motor
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
On a stock 1987 IROC 305 TPI we put a single turbo ( Holset HX50 ) and a front mount intercooler. We only installed larger injectors on the engine and changed the tuning in the chip. To get away with the stock compression we converted to Ethanol (E85). We only used about 12 psi boost because the stock ingnition could not handle any more.
With a th400 and the stock 2.73 rear it ran 105 mph in the 1/4 mile and that translates to about 350 rwhp. The stock engine has 190 crank hp.
no green
Jan 9, 2016 09:22 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
