Nitrous on a Stock Block
Old Sep 14, 2006 | 08:29 PM
93Z28rare's Avatar
Hey everyone. I was wondering if anyone knew if the stock 5.0 TPI block in a 1988 GTA could handle a 100 - 150 nitrous shot safely? Thanks.
Carlos
Old Sep 14, 2006 | 09:07 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Small V8s can typically accept up to 140 extra horsepower, this range will provide maximum reliability from stock motors using cast crankshafts and pistons with few or no motor modifications.
Old Sep 16, 2006 | 02:31 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I second that notion. Your 305 should work great at a little under the 150 jetting NOS recommends in there TPI kit (.058 to a .061 jet). This will get you the max performance out of the nitrous and not risk killing your engine. I recommend highly that you do a 180 degree or lower T stat and keep the car under 200 degrees when you run the spray. With this setup you should be fine with stock heat range plugs and timing.
Old Sep 16, 2006 | 10:29 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I am up to a 145hp dry shot with my Zex kit.
Stock block, stock heads.
Old Sep 16, 2006 | 01:03 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i have a .061 nitrous jet on my wet kit for my 305 tbi. works wonders and car hauls ***.
Old Sep 17, 2006 | 03:10 AM
93Z28rare's Avatar
Thanks. I was hoping to hear at least 150. Now is that a wet or a dry shot??
Old Sep 17, 2006 | 10:29 PM
Engine: LO3
150 is pushing mine i think is a 130 as im told but it pulls real nice last night at a 25 mph roll in an LO3 let me remind you otherwise pretty much stock i spun like a **** and made a huge cloud it made that much of a difference
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
