nos 100 shot - after market chip
Old Oct 2, 2006 | 11:09 AM
graphicideas1's Avatar
i am installing a 100 shot wet kit from zex - i have a 350 l98 - lt4hotcam & headers - with a aftermarket chip what do i need to do with my timing? the instructions say to retard 4' but the chip has built in advance - now what?
Old Oct 2, 2006 | 11:22 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Get your timing light out and pull 4 degrees of base timing out. It will be a tad hard to start but that should work. If not copy your prom and burn the timing advance table with - 4 degees (assuming you do your own prom burning).
Old Oct 2, 2006 | 11:29 AM
4' out - but that should only bring it back to stock from what the chip added??? I have a pcm for less chip
Old Oct 2, 2006 | 11:39 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
you could just run higher octane without pulling timing. by higher octane i mean like 100. 93 you might get away with very little timing change needed. i run 93 on my 130 shot and from what i feel from -4 degrees i think i can bump it up a couple but id rather be safe then sorry so im leaving it
Old Oct 2, 2006 | 03:47 PM
a 100 shot shouldn't need any timing retard and should run fine on 91 octane, take it out 6 degrees on the distrubutor if you want to be extra cautious but it should be perfectly fine with 4 degrees out. Also jet rich when you start out and if it black smokes or doesn't have much power lean out from there.
ChristinaMarie
Sep 11, 2015 06:28 PM
Ranbo108
Sep 9, 2015 12:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
