single turbo on TBI
Old Oct 8, 2006 | 09:27 PM
5 Spd Formula's Avatar
single turbo on TBI
can it be done .. like make a box to surround the top of the throttle body.. with more fuel pressure..bigger injectors.. and lower psi turbo like 6-7 psi..its a 305 motor with 57,000 miles on it..
can it be done
Old Oct 8, 2006 | 10:05 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yes, it can be done.
Old Oct 8, 2006 | 10:20 PM
:-) my night was just made...
where can i find some pics? does anyone have a tbi turboed? or a list of what all i shoudl get besides turbo and oil lines.. i found single turbo manifolds for cheap and i think im gonna get them
Old Oct 8, 2006 | 10:33 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Click on this link Welcome to Turbo Mustangs.com and do a search for tbi turbo. You probably need to be a member to see the pics.
Beware of cheap headers. Some are good and some will crack and fall apart. Turbos make a lot of heat in the exhaust manifolds and makes them more prone to cracking.
You need:
ECM programming for fuel(bigger injectors) and spark or FMU and timing retard box.
Pipe for the intake and exhaust
oil feed and return lines
air filter
exhaust manifolds and good gaskets
You may need:
bigger tires
better suspension
stronger rear-end
stronger transmission
Old Oct 8, 2006 | 10:50 PM
i have ws6 suspenion and 255/50 or 255/55 R16s on my car
Old Oct 8, 2006 | 11:02 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I wish I had a pic of the headers glowing red after a hard run the other night. It would give you an idea of how hard turbos are on exhaust manifolds.
Old Oct 13, 2006 | 03:11 PM
3rd-gen junkie's Avatar
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
I am working up a project that will involve a single M90 supercharger (duals down the road) on a 305 TBI car. I have all my mounting hardware the only obstacle ahead of me is tuning... any ideas on how to figure out which injectors I need to upgrade too and how to tune this thing? I was going to use a carb but want the luxury of fuel injection for the sake of a remote car starter (alright, hahahahaha, call me a p*ssy but it gets cold in this state). I am not very knowledgeable with fuel injection other than I can't use a screw driver to adjust it. ANY suggestions would be appreciated at sole6454@kettering.edu
Old Oct 13, 2006 | 03:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Download this calculator:: http://www.gnttype.org/techarea/turbo/turbocalcs.xls
Put in your RPM, engine size, IAT, boost, and it will tell you what size injectors that you will need.
EDIT: If you install an FMU, then you can use a screw driver or wrench to adjust it.
Old Oct 18, 2006 | 10:51 AM
83 Crossfire TA's Avatar
Because of the low pressures that the TBI setup runs at FMU ratio/tuning is especially fussy with them, personally I wouldn’t recommend it unless you’re very good at tuning in the first place.
Otherwise, injector size: if you’re going to get into programming/chips then just get the biggest that you can actually get your hands on. I believe they used to be available up to 96lbs/hr, the big block injectors are somewhere in the mid 70’s. You’ll probably end up running the big block injectors and a vacuum referenced regulator or at least higher then stock fuel pressure.
Bubbajones_ya
Jul 6, 2024 08:32 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
