nitrous+stroker=????
Old Oct 15, 2006 | 08:26 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
is it ok to add nitrous to a stroker? just leik a 50 or 75 shot? mines a stroked 383 w/ corvette 113 aluminum heads, 10.5 to 1 if that helps
Old Oct 15, 2006 | 08:51 PM
Steven89Iroc's Avatar
The fact that it's a stroker doesn't have anything to do with it. Nitrous will work with any bore and stroke if done right.
I'm pretty sure a 50 or 75 shot wouldn't harm your engine at all if it's set up properly unless you're at the power level limits of your bottom end or something, but that's doubtful.
Old Oct 15, 2006 | 09:27 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alrihgt well yea i was jw cuz its stroked. u know of any good n20 kits
Old Oct 15, 2006 | 09:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
NX is one of the best kits on the market
Old Oct 15, 2006 | 09:51 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
ill check it out thanx
Old Oct 17, 2006 | 11:47 PM
stroked383z's Avatar
nitrous+stroker=???? =bad sum bitch
i like the n.o.s. direct port fogger
Last edited by stroked383z; Oct 17, 2006 at 11:48 PM. Reason: Automerged Doublepost
