ran my iroc-z saturday
Old Oct 15, 2006 | 08:47 PM
superirocz's Avatar
Made a couple passes yesterday with my 89 iroc-z twin turbo and busted my stock 9 bolt rear.
car is full weight 89 iroc
355 4 bolt with trw pistons flat tops, stock rods/crank
AFR 210 heads 67cc summit $50 cam 224/224l
6 speed with stock rear 9 bolt 3:08 gears with twin t-70 master power turbos at 10psi. I made 2 low 12 second times at 127mph on my 17x11 bfg drag radials and then I lowered the presure on them and launched at about 3500 and went a bogged 11.7@128 with a 1.98 60 foot. Next pass launched it about 4300 and the posi broke. I have been driving the car all summer but have had all sorts of issues and just now got to a track to race my beast. I did build everything myself
Old Oct 15, 2006 | 08:54 PM
Steven89Iroc's Avatar
Nice, I see you built a different turbo setup than you had before? Looks great.
Time for a 9"?
Old Oct 16, 2006 | 04:24 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
nice!, that sucks about your rear, i broke my 10 bolt with drag radials and a manual recently.
Old Oct 16, 2006 | 05:13 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Real good numbers, get it fixed and get it to hook up and you'll break 10's no problem. Good job, looks real nice.
Old Oct 19, 2006 | 04:22 AM
83 Crossfire TA's Avatar
At least mid 10’s… time to fix your sig…
Old Oct 21, 2006 | 07:48 PM
superirocz's Avatar
I pulled the rear cover of the diff and I broke an axle so I got a set on the way and will be going back to the track next saturday
Old Oct 21, 2006 | 08:21 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
get a stud girdle cover and weld the axle tubes...helps quite a bit
Old Oct 22, 2006 | 01:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What induction on that?
Why did you pick that particular cam?
Very good combo there, is it intercooled?
Old Oct 22, 2006 | 08:20 AM
superirocz's Avatar
Holley steath ram. I picked that summit cam cause it was $50 bucks. Other then the heads that engine is cheap I paid about 750 for the rest of the motor and the those intakes are pretty cheap to. I even got that FAST ecm brand new from a shop going out of buisness for half price.
Old Oct 22, 2006 | 01:18 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
128MPH in the 1/4? Sounds like a ton of fun to me!
Was this run at BSD?
Old Oct 22, 2006 | 08:04 PM
superirocz's Avatar
yes BSD
I have a turbo 350 with a shift kit I may throw in it for this weekend.
Old Oct 23, 2006 | 02:18 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Where did u get those manifolds your setup is sick!!
Old Oct 23, 2006 | 08:41 PM
superirocz's Avatar
I made the headers my self. I bought u bends and flanges and collectors and just started cutting fitting and welding away at it.
Old Oct 23, 2006 | 08:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
stainless or mild steel?
Where'd you get the bends, flanges, collectors?
How much did it run ya?
MIG, TIG?
Sorry for the barrage, but i'm considering doing this kind of thing soon, and i'm planning and pricing things out.
Old Oct 23, 2006 | 09:59 PM
superirocz's Avatar
I got the flanges online for $25
Hooker 3 inch collectors hooker mandrel bends
materials were about $260 and its mild steel just need to coat them and they will last forever. TIG welded, here is a shot of what I started with
Old Oct 23, 2006 | 10:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Holy cow that's a lot. I didn't think mild steel bends would run $260.... Hmm, interesting.
I can't enlarge that picture, so i'll trust ya
Thanks for the info.
Old Oct 23, 2006 | 11:15 PM
superirocz's Avatar
I think 11 u-bends at $13 a piece two t-4 flanges, 2 header flanges, 2 collectors,3" u bend and 2 wastegat flanges. It adds up.
Old Oct 25, 2006 | 04:25 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
twin t-70's is a lot of air, I'd hope it went faster than 10's after everything is sorted out.
Old Oct 25, 2006 | 07:26 PM
superirocz's Avatar
when its all said and done I want 8.9s at 155mph but I need a shortblock and a turbo 400
Rocket-Doc
Nov 14, 2015 02:08 PM
darwinprice
17
Oct 11, 2015 11:51 PM
88CamZ
Oct 8, 2015 10:29 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Linson
Oct 1, 2015 09:50 PM
