Need Help With Procharger Belt Length
Old Nov 3, 2006 | 05:36 PM
Procharged GTA's Avatar
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
Hi, my dad has a 86 Trans Am that has a 383 with a D1SC Procharger on it. It currently has a 4.25" 8 rib pulley,and it pumps about 6-7 lbs. of boost. We are going to change the pulley to a 3.70" pulley to get the boost up to around 10-12 lbs. He called ATI today and they said that going from the 4.25" pulley to the 3.70" pulley would increase the boost around 5 lbs.,so that would put him in the 10-12 lb. range. I need to know what belt to buy for the new 3.70" pulley? We have had experience with the Prochargers in the past,and found out that a belt that is 1/2" shorter than ATI recommends gives more belt tensionor room. The crank pulley is a 7.65" TPI crank pulley.
Can someone give me a part# or belt length to run with the 3.70" pulley?
Old Nov 3, 2006 | 11:22 PM
KS91Z28's Avatar
I always went to the parts store and bought the next few sizes smaller and returned which ever ones I didn't need.
Old Nov 4, 2006 | 03:51 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Damn wish it was that easy with a 12 rib
Old Nov 4, 2006 | 06:03 PM
KS91Z28's Avatar
It's almost that easy. You just have to buy 2 6 rib belts.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
