Procharger Parts for use with 749 ECM
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I want to run a Procharger P1SC supercharger. I am going to convert my 730ECM to a 749 ECM. I already have a high flow in-tank fuel pump. Aside from the supercharger itself, what other parts will I need? I do not need the entire kit from procharger, so I want to know if someone, who has done this, can tell me what parts they needed and where they got them. Thanks.
Engine: L98 355
Axle/Gears: 3.70
Well...are you saying that you only have the hi-flow pump and nothing else? if so, then you pretty much do need the entire kit, minus the pump. Off the cuff, you'll need
head unit
bracket
head unit pulley
crank pulley
tensioner pulleys
belts
blow-off valve
BOV pipe
FMU
fuel hoses for the FMU
boost gauge (not included in the kit AFAIK)
intercooler
intercooler piping
misc. bolts, hoses, couplers, etc.
head unit
bracket
head unit pulley
crank pulley
tensioner pulleys
belts
blow-off valve
BOV pipe
FMU
intercooler
intercooler piping
Car: 1989 GTA
Why would i need a FMU if i am converting to the 749 ECM and a 2 bar MAP
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
WB02 setup for data logging would be nice and maybe some injectors but chances are your not going to get a better deal buying the procharger parts separate then just getting a kit.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
No FMU and you will be running bigger injectors. I didnt get an FMU for multiple reasons and went with SVO 42's
LT1Formula
20
Nov 14, 2015 12:02 AM
