Turbo choice?
Old Dec 7, 2006 | 11:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Turbo choice?
Say if I wanted to turbo my 383 instead of supecharging, What would you guys recommend I go with? I am clueless at turbos and them damn numbers.
I will probably build the engine for 8.2:1 CR.
AFR 195 heads, Miniram, and a custom cam grinded to a good turbo spec.
RPM range i want to be shifting at is around 6000 through 6500 at most. I don't want to overstress the engine if I dont need too.
I would like to get between 500-600rwhp.
the engine will have all forged internals.
What would you recommend?
Oh yea, I wanted to add this needs to be on pump gas. 91 octane.
Old Dec 7, 2006 | 11:26 PM
truckerdraven's Avatar
Car: 84 camaro berlinetta
Engine: 305ci v8 carb
Transmission: auto
i would go for a twin turbo setup 2 t3 .63 trim garrett turbo's so you can use 2 smaller turbo's so there is not as much lagg as 1 big turbo.
Old Dec 7, 2006 | 11:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I would awnt to set it up like sts with one turbo out back.
Old Dec 8, 2006 | 01:53 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Keep it in the engine compartment, run a single T76 w/ .96 A/R Q trim on the exhaust side.....perfect for you power goals and should spool quickly....
Old Dec 8, 2006 | 11:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Why keep it in the engine bay?
Old Dec 8, 2006 | 09:24 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
I dont care what any person or company claims....the engine bay is more efficient than any remote mount, Plus if you think about this...a good turbo is about $1000, a remote mount kit is like setting $1000 dollars on the sidewalk in LA and not expecting anyone to take it......Heat is a major driving force of turbocharging, with a remote mount it just seems there would be a lot more backpressure due to using smaller turbine housings....and a great loss of the energy that helps drive the turbo....I just don't see major power as easily accessable from a remote mount kit.
Old Dec 8, 2006 | 11:01 PM
daves12secV6's Avatar
not only that id be worried about the electric oil return pump burning out or not working right,and blowing out a seal in the turbo or otherwise causing damage
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
