how much nitrous is too much?
Old Dec 31, 2006 | 09:57 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
well here is what i have got. a 383 with edelbrock performer rpm intake and a 750cfm performer carb with a 11:1 compression alluminum heads and 200cc intake runners and stock 5.7 350 rods and arp rod and head bolts. what i would like to know how much of a shot of nitous i can get away with. i have 6000 invested and dont wanna blow it apart. i just want a little extra boost at the track. i may or may not do this but its just a thought for now. what does everyone think???
Old Dec 31, 2006 | 10:09 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
You didn't mention what kind of pistons you have (cast/hyper/forged)... The basic rule of thumb is that for "serious" or regular shots of giggle gas, you really need forged.
Hypereutectic pistons will (probably!) be OK for the occasional track day, assuming that you don't go crazy w/the spray, but (personally) I'd be a little bit cautious given your compression ratio.
If they're cast pistons (unlikely at an 11:1 CR), I myself wouldn't even hit the button until I swapped 'em out. My best guess is that you'd probably be OK with a 75, maybe 100 shot, since you have Alum. heads... (But I'm sure others here can give you better/more-specific info)
Old Dec 31, 2006 | 10:13 PM
Car: 85 trans am
Engine: 383 stroker
the pistons are hyper, and the crank is cast i think i dont remember on the crank
i really wasnt lookin to really go crazy with it and also should i use a wet or dry shot?
Old Dec 31, 2006 | 10:26 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I am thinking that you have a stock 5.7 rods, you are pushing the limits naturally aspirated, i have the same rods and it scares me to rev to 6000 rpm, i would not think of using dope without a stronger rod.
Old Dec 31, 2006 | 10:29 PM
Car: 85 trans am
Engine: 383 stroker
first im gonna see what i can pull at the track when i put in my new posi unit with 3:70's in my nine bolt but the spray is just a thought rollin around in my head.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
