electric superchargers???? anyone tried it? are they a joke??
Old Jan 1, 2007 | 03:12 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Seems kinda silly but maybe I'm not being open minded...
They claim 2 psi, which I guess is an improvement if you're just going for something better than stock.
Anyone tried these things or know someone who has?
Are they a joke? Any improvement?
I'm just wondering, ran across one when I searched 'turbo' on Ebay the other day and had to click on it
Old Jan 1, 2007 | 01:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes its a joke. They're more of an air restriction than an air mover. Same with the Tornado and that other junk.
Old Jan 1, 2007 | 05:45 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It will not create boost at any usable RPM. It is only a joke if you don't buy one. The people that wasted money on them don't usually laugh about it.
More and more ebay sellers associate junk parts with turbo. It clogs up the search engine and makes you have to search for specific things.
Old Jan 1, 2007 | 09:44 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
haha, just for laughs go read the feedback for "electricsuperchargers4less"
what a bunch of tools.
Old Jan 1, 2007 | 09:48 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Yea it would make sense it wouldn't work either, but I found a video a while back proving that it at least has some affect. I laughed so hard I almost fell out of my chair the first time I saw the video. How you would mount it up inside the engine bay would be nearly impossible.
http://videos.streetfire.net/iPlayer.aspx?fileid=AB544E3B-5DFF-416D-9CFD-A1AD23CA9564
enjoy.
Old Jan 1, 2007 | 10:01 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
lol I am going to get a twin leaf blower set up now
Old Jan 1, 2007 | 10:31 PM
Tobias05's Avatar
wow...kids these days.
Old Jan 1, 2007 | 11:37 PM
junkcltr's Avatar
Engine: 3xx ci tubo
A remote mount twin leaf blowers powered by a couple of CR250 2-strokes would be the hot setup. Weight in the rear, and not much weight for the setup. No engine loss in HP.
Old Jan 6, 2007 | 12:41 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
hell, while we are at it, why not hook up a compressed air tank and shoot 10 psi in the TB cheaper than nitrous lol....
Old Jan 6, 2007 | 08:25 AM
Damon's Avatar
The basic problem with electric turbochargers is that it takes a MASSIVE amount of electrical energy to move enough air to make meaningful boost. WAY more than your car's electrical system could make. I know I built one with my brother years ago using the compressor side of a T-73. With a 36V system and a ton of amperage it might make a couple pounds on a small V8 (judging by our testing of impeller speed and observed boost on a test bench). Even then the batteries were flat in no time. It would be, at best, like a nitrous system- for short term use only. And HEAVY with all the batteries.
Old Jan 6, 2007 | 08:57 AM
firstfirebird's Avatar
HAHA, Ive never seen that done on a dyno before! Seen vids like that before.
Hey bazooka, next time please use the search function before you post a new thread, this same question is on here a few times already. And better explains why it doesn't work, ie watts vs. horsepower.
You have to remember that a turbo spins in excess of 100,000rpm, unless you can achieve that with an electric motor that's also strong enough to rotate against the boost, well...
Old Jan 6, 2007 | 02:28 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm shocked...lol. I'm sending that vid to everyone I know.
Old Jan 8, 2007 | 11:18 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I thought Mad Max used it effectively on his Ford Falcon. I'm so disappointed.
Old Jan 10, 2007 | 09:23 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Max used a roots style blower. Also thought it was weird
how he had his on a switch, sort of like a clutch that he could disengage the blower. I don't think that is possible.
Old Jan 10, 2007 | 10:18 PM
Guest
Guest
Posts: n/a
Ask the expert. lol
It wasnt hooked up to the engine, so the story goes. It was bolted to the hood and they used an electric motor to spin the pulley. They say it cant be done, but I dunno... some of those AC clutches and electric controlled engine fan clutches out there (like in big trucks) will hold quite the load. An appropriate sized electromagnet might do it, but not sure how well the engine would run trying to suck through a roots. Ive heard you can but its highly unadviseable.
Old Jan 10, 2007 | 10:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
FWIW, Ive heard values as high as 60 HP to operate a supercharger on some factory cars, so it takes some serious power to build good boost. Makses sense if your compressing hundreds of CFM of air.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
