Nitrous Question
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Nitrous Question
Hey guys I wanted to verify something. In my pic I have the injector plate right directly underneath the carb and my idea was to move it under the carb and the spacer to provide some more room for the solenoids. Would the plate still work the same even if I moved it further down the manifold instead of right under the carburetor? Im thinking it shouldn't make a difference but I just wanted to get another opinion.
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
last year with my 377 , i ran my plate below my 1" spacer. this year it is above the spacer with a 408. i honestly cant tell much of a difference (in spray). the tech guys at NX told me to spray it with the plate in both spots with the manifold off to see if there was a difference in the discharge at the ports. i didnt.best way to tell might be to do back to back test at a track.
Engine: 584
I dont really see how it could have any effect on anything as long as the plate is injecting it at the right angles. I guess I will go ahead and move it down and try it out.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
