how much spray
Old Jan 30, 2007 | 06:26 PM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
how much spray
How much spray on cast pistons???? How much is safe
Old Jan 30, 2007 | 07:13 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Off the top of my head, you can go 100 and be safe, i see no reason why you couldn't go 150, but correct me if I'm wrong, i have sprayed a 305 92 RS for 1 year with a 200 shot, failure was finally due to fuel pump failure, i thought they were cast, but may have been hypers. i am not 100 percent sure.
Old Jan 31, 2007 | 05:05 PM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Thats what I though I am probly going to put a 75 shot of spray on it that way I do not comprimise the life of the engine.
Old Jan 31, 2007 | 11:56 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I ran a .070 jet on my Camaro since day 1, upped to a .073 this last year, going to a .078 next year; this is all on a stock bottom end with a TON of miles. Really the only limiting factor is fuel and pumping losses. I'de do a 250 plate shot on a single plane carb manifold with a stock bottom end, as long as I had the fuel and exhaust system to support it. I've heard that a stock headed small block will limit itself at around a 350hp shot due to the exhaust ports being incapable of flowing the massive ammount of exhaust gas. Massage the exhaust ports, stick 1.6 or 1.65 exhaust valves in with the 1.94 stock intake valves and you should be able to spray ALOT. Finally you'll crack a piston from ring expansion, or collapse a rod but hey it'll be fun while it lasts.
Old Feb 5, 2007 | 01:57 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
is the NOS tbi kit a wet or dry system?
Old Feb 5, 2007 | 02:08 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
i wouldnt go over 125hp kit, if you do go more watch your fuel pressure.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Oct 7, 2015 10:15 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
