Is this a good turbo??
Old Jan 30, 2007 | 10:41 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Can get a good deal and was wondering if itd be of decent size for a 3.4 Im building.. 1.05 A/R and a compressor of .60 Thanks
Old Jan 30, 2007 | 11:00 PM
daves12secV6's Avatar
that 1.05 ar turbine might spool up @ 6,500 rpm + on 3.4.most of the 3.4 guys i know use a .63 or a .84 housing and even the .84 guys complian of to much lag
Old Jan 30, 2007 | 11:53 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If that is a T3 or T4 1.05 A/R turbine then I would think that Dave is correct.
Old Jan 30, 2007 | 11:58 PM
Im just confused cause the damn 3.0L Supras can use those turbos so how could a larger 3.4 lag too much?? Ill take your advice tho and go for a .63... How much hp can those support?
Old Jan 31, 2007 | 12:02 AM
junkcltr's Avatar
Engine: 3xx ci tubo
The Supra engine technology is different. Yes, they have lag with one of the those turbos. How much lag are you willing to stand in order for more top end HP?
Rule of thumb, smaller turbine gives faster spool. Larger turbine gives more top end power. There is a lot more to it than that, but it gives you a general idea of what turbines do.
EDIT: A stock Ford 2.3 liter came with a T3 .63 A/R turbine and so did the 300ZX 3.0 liter single turbo cars. Just to give you an idea of what the factories used for turbines.
Old Jan 31, 2007 | 12:08 AM
junkcltr's Avatar
Engine: 3xx ci tubo
It is tough to say how much HP it will support. I have never seen a Garrett turbine map for a T3 turbo. I use the garrett GT turbine maps posted at their site and match up flange, wheel, and A/R. I figure out the spool time and HP using those maps to get a ROUGH idea of what the turbine will do.
Old Jan 31, 2007 | 12:43 AM
Are compressor sides interchangeable at all? Like if I had one T04 that was like turbine .70 and compressor .40 and another that was .63 turbine and .50 compressor?? Could I swap the compressor sides??
Old Jan 31, 2007 | 09:47 PM
as long as the shafts are the same size u could swap the compressors,though if both turbines are t3 stage 3 wheels u could just swap the ex housings as well.
dending on how well the heads flow and the intake is id prolly go for a t61, 60-1, or a t-70 for that sized engine,but u need to check the maps for efficiancy for whatever boost level u plan on running
Old Feb 2, 2007 | 05:15 AM
Gonna be fully ported iron heads and a completely custom intake setup. The heads would be the only thing Im worried about as far a restrictions.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
PestilenceIV
Aug 20, 2015 03:32 PM
